sweetmelissa Posted November 14, 2024 Share Posted November 14, 2024 When I add this text to the segment on this dimension line and then "suppress the dimension" it turns the color of the text from the normal blue to this other color. I cannot find where this setting is to change it. Anyone know? Thank you. Link to comment Share on other sites More sharing options...
joey_martin Posted November 14, 2024 Share Posted November 14, 2024 Are adding text OVER the dim line or using the text options within the dimension dialog box? Link to comment Share on other sites More sharing options...
MarkMc Posted November 14, 2024 Share Posted November 14, 2024 I can't reproduce the problem. I'd start by saving and reopening, maybe even reboot. Try a new file and see if that does it. Post plan with problem. Link to comment Share on other sites More sharing options...
Solution JKEdmo Posted November 14, 2024 Solution Share Posted November 14, 2024 1 hour ago, sweetmelissa said: When I add this text to the segment on this dimension line and then "suppress the dimension" it turns the color of the text from the normal blue to this other color. I cannot find where this setting is to change it. Anyone know? Thank you. Melissa, Possibly this setting? The setting highlights dimension text that has been "messed with." Which is explained in Help here: 3 Link to comment Share on other sites More sharing options...
sweetmelissa Posted November 14, 2024 Author Share Posted November 14, 2024 That was exactly the problem! Thank you very much for finding that for me! And thank you Joey and Mark for the responses! 7 minutes ago, JKEdmo said: Melissa, Possibly this setting? The setting highlights dimension text that has been "messed with." Link to comment Share on other sites More sharing options...
tundra_dweller Posted November 15, 2024 Share Posted November 15, 2024 On 11/14/2024 at 12:35 PM, JKEdmo said: The setting highlights dimension text that has been "messed with." Great catch! Another setting I did not notice that existed. Link to comment Share on other sites More sharing options...
