johnny Posted September 17, 2024 Share Posted September 17, 2024 Is there a way to get a custom fence panel to run through the posts? Link to comment Share on other sites More sharing options...
Gawdzira Posted September 17, 2024 Share Posted September 17, 2024 Make the posts really, really small. Link to comment Share on other sites More sharing options...
johnny Posted September 17, 2024 Author Share Posted September 17, 2024 7 minutes ago, Gawdzira said: Make the posts really, really small. ....and then just manually put posts in after? I guess that would work. Thats too bad there isn't a way around this to have my cake and eat it too so its automatic. Link to comment Share on other sites More sharing options...
johnny Posted September 17, 2024 Author Share Posted September 17, 2024 20 minutes ago, Gawdzira said: Make the posts really, really small. Overall kinda works - but the corners are a problem. I can't seem to get the wall intersection tool to miter the corners. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 17, 2024 Share Posted September 17, 2024 Or no boards that are part of the fence, and make the panels with moldings. Link to comment Share on other sites More sharing options...
ValleyGuy Posted September 18, 2024 Share Posted September 18, 2024 4 hours ago, johnny said: Is there a way to get a custom fence panel to run through the posts? Exposing the framing of a half wall with girts and a cap looks fairly close. You could put all this framing on a new layer line to show it whenever you needed to. Not exactly sure what you might need to tweak to get it to fit your application or terrain, but it's an idea... 1 1 Link to comment Share on other sites More sharing options...
ValleyGuy Posted September 18, 2024 Share Posted September 18, 2024 Off setting girts on both sides looks even better.... 1 Link to comment Share on other sites More sharing options...
johnny Posted September 18, 2024 Author Share Posted September 18, 2024 2 hours ago, ValleyGuy said: Exposing the framing of a half wall with girts and a cap looks fairly close. You could put all this framing on a new layer line to show it whenever you needed to. Not exactly sure what you might need to tweak to get it to fit your application or terrain, but it's an idea... That does look good - i'll try. Link to comment Share on other sites More sharing options...
