Garreth Posted August 22, 2024 Share Posted August 22, 2024 Hello all is there any way to manually adjust the row height for the schedules. The schedules are way to big... Link to comment Share on other sites More sharing options...
MPDesign Posted August 22, 2024 Share Posted August 22, 2024 Hi Garreth, I think you can change the text style for the schedules by the layer (look in Active Layer Display Options) under schedules and change to 1/4" or 1/2" text style) or the individual schedules to use a custom size under the main title on the left of the dbx. Link to comment Share on other sites More sharing options...
Doug_N Posted August 22, 2024 Share Posted August 22, 2024 Just a suggestion for now to make the schedule more proportional (in my opinion) Link to comment Share on other sites More sharing options...
DBCooper Posted August 22, 2024 Share Posted August 22, 2024 Short answer, yes. Long answer, how also depends on whether your schedule is showing previews. If you have previews, the row height is probably being set from the size of the preview. Doing like Doug shows where you make the column width smaller will usually make the row height smaller. The row height is also determined by the size of the text style used but you can also have either top or bottom margins set. If you want a better answer, posting a picture of what your schedule looks like would help. Link to comment Share on other sites More sharing options...
