Hannahfdc Posted August 7, 2024 Share Posted August 7, 2024 my roof planes are not aligning. when I join them, they don't center over the porch. I also moved the door over slightly and the floor disappeared. There also appears to be a hole in the wall. Link to comment Share on other sites More sharing options...
basketballman Posted August 7, 2024 Share Posted August 7, 2024 P.M. sent ... Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 7, 2024 Share Posted August 7, 2024 On 8/7/2024 at 3:40 PM, Hannahfdc said: my roof planes are not aligning. when I join them, they don't center over the porch. I also moved the door over slightly and the floor disappeared. There also appears to be a hole in the wall. Expand I would guess that the baselines for those roof planes are not sitting on the outside main layer of the exterior wall. It may be easier to take the roof plane that has the correct seat cut and copy/paste and then reflect about an object that is center to your ridge. 1 Link to comment Share on other sites More sharing options...
SNestor Posted August 8, 2024 Share Posted August 8, 2024 @Hannahfdc - If you would post your plan one of the Chief experts on this forum will give you guidance. Otherwise we are all guessing. Link to comment Share on other sites More sharing options...
Hannahfdc Posted August 8, 2024 Author Share Posted August 8, 2024 So I got the roof sort of figured out. But now I am unable to get the beans of the porch aligned as well as the floor is missing. GC plan to upload for question.zipFetching info... Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 8, 2024 Share Posted August 8, 2024 change the room to a balcony and build all framing Link to comment Share on other sites More sharing options...
SNestor Posted August 9, 2024 Share Posted August 9, 2024 To get the floor...just open the room and on the deck tab, select "automatically regenerate deck framing". Just ignore the warning...you are building a deck over a room below (another deck in this case)...which Chief just cannot seem to contemplate. Link to comment Share on other sites More sharing options...
SNestor Posted August 9, 2024 Share Posted August 9, 2024 @Hannahfdc - I messed around with your plan...fixed a few things and modified the roof design. Not sure it's what you want...but maybe it'll serve as inspiration. Your deck rooms were named as "porch"...I changed them to "deck". If you don't want them to be decks...I'd change them to "balconies". Greg Plan - Roof Example.zipFetching info... Link to comment Share on other sites More sharing options...
