EmVann Posted August 6 Share Posted August 6 Hey there everyone! I am a new user who just recently started using this program and I am in a bind on how to go about understanding how Calibz files works. Long story short, I had recently downloaded Rabbit Designs Free symbols which are Calibz Files and I was notified that it would or should work on X15+ newer version. However I am unable to import the files successfully. Is there something I am doing wrong that someone may advise? I also did the drag and drop onto the open window- which didn't work. Much thanks for your understanding and patience everyone. Link to comment Share on other sites More sharing options...
Gawdzira Posted August 6 Share Posted August 6 Import through the Library tool. Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 Hey there! i had done that as well and nothing was imported it said it wasn't successful Link to comment Share on other sites More sharing options...
GeneDavis Posted August 6 Share Posted August 6 Show us the .calibz file in the folder that won't import. Post it here. Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 This is just one of many of Rabbit Designs Calibz I downloaded. All of them was not able to import.https://www.rabbittdesign.net/symbols <-- this is where I downloaded the files. Rabs+Sink+Faucet+and+Chop+Combo.calibz Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 6 Share Posted August 6 8 minutes ago, EmVann said: This is just one of many of Rabbit Designs Calibz I downloaded. All of them was not able to import.https://www.rabbittdesign.net/symbols <-- this is where I downloaded the files. Rabs+Sink+Faucet+and+Chop+Combo.calibz 5.65 MB · 1 download Can you screenshot any dialog messages you get when you try and import? Can you screenshot your library browser? I just dragged and dropped the file you uploaded and it installed right away Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 Here you go! Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 6 Share Posted August 6 4 minutes ago, EmVann said: Here you go! can you screenshot the part of your library that is the user catalog. It seems like you've already successfully installed these items which will be in your user catalog Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 6 Share Posted August 6 4 minutes ago, EmVann said: none of those screenshots are showing your user catalog. Its been a long while since I had zero items in my user catalog but I believe by default it still shows up even if you have no items in it Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 Apologies I do not see a User Catalog on my program Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 6 Share Posted August 6 Just now, EmVann said: Apologies I do not see a User Catalog on my program select any item from any other catalog and choose to copy to user library, and see if you have a user library folder then Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 I copy to User Catalog but it doesnt show any folder Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 6 Share Posted August 6 Just now, EmVann said: I copy to User Catalog but it doesnt show any folder do you have any active filters in your search, please cancel any filters you have. on youre previous search you had bathroom mirrors and frames as an active filter Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 I have these two errors when i restart my program Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 4 minutes ago, Renerabbitt said: do you have any active filters in your search, please cancel any filters you have. on youre previous search you had bathroom mirrors and frames as an active filter Nope, I cancel all filters. I even went to the data folder and don't see a user folder as well in the Premier data Folder Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 6 Share Posted August 6 6 minutes ago, EmVann said: I have these two errors when i restart my program I personally suggest that you change the location of your data folder as it is in the Documents folder which is a folder that by default in win 11 is on OneDrive and onedrive can cause problems with chiefs database system. You should call in to their support Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 Ah okay thank you. I redirected the Data folder to another location but it still shows the error. thank you maybe i should reinstall who knows. Link to comment Share on other sites More sharing options...
Solution Renerabbitt Posted August 6 Solution Share Posted August 6 1 minute ago, EmVann said: Ah okay thank you. I redirected the Data folder to another location but it still shows the error. thank you maybe i should reinstall who knows. Try deleting the user library data file with chief closed and then re-open chief and it will rebuild the file 1 Link to comment Share on other sites More sharing options...
Dermot Posted August 6 Share Posted August 6 Here are a couple of tech articles that might help: https://www.chiefarchitect.com/support/article/KB-01759/troubleshooting-compatibility-problems-with-library-content.html https://www.chiefarchitect.com/support/article/KB-02772/troubleshooting-library-download-issues.html You may want to contact tech support on this one though because your user library might be corrupt. Link to comment Share on other sites More sharing options...
EmVann Posted August 6 Author Share Posted August 6 14 minutes ago, Renerabbitt said: Try deleting the user library data file with chief closed and then re-open chief and it will rebuild the file It worked! also successfully imported your files as well! yay! i also relocated the folders beforehand. thank you alot! Link to comment Share on other sites More sharing options...
