X16 Not able to Import Calibz Files
EmVann
Go to solution Solved by Renerabbitt,
Hey there everyone!
I am a new user who just recently started using this program and I am in a bind on how to go about understanding how Calibz files works.
Long story short, I had recently downloaded Rabbit Designs Free symbols which are Calibz Files and I was notified that it would or should work on X15+ newer version. However I am unable to import the files successfully.
Is there something I am doing wrong that someone may advise? I also did the drag and drop onto the open window- which didn't work.
Much thanks for your understanding and patience everyone.
8 minutes ago, EmVann said:
This is just one of many of Rabbit Designs Calibz I downloaded. All of them was not able to import.
https://www.rabbittdesign.net/symbols <-- this is where I downloaded the files.
Can you screenshot any dialog messages you get when you try and import?
Can you screenshot your library browser?
I just dragged and dropped the file you uploaded and it installed right away
4 minutes ago, Renerabbitt said:
do you have any active filters in your search, please cancel any filters you have. on youre previous search you had bathroom mirrors and frames as an active filter
Nope, I cancel all filters. I even went to the data folder and don't see a user folder as well in the Premier data Folder
6 minutes ago, EmVann said:
I have these two errors when i restart my program
I personally suggest that you change the location of your data folder as it is in the Documents folder which is a folder that by default in win 11 is on OneDrive and onedrive can cause problems with chiefs database system. You should call in to their support
  • Solution
1 minute ago, EmVann said:
Ah okay thank you. I redirected the Data folder to another location but it still shows the error. :( thank you maybe i should reinstall who knows.
Try deleting the user library data file with chief closed and then re-open chief and it will rebuild the file
Here are a couple of tech articles that might help:
https://www.chiefarchitect.com/support/article/KB-01759/troubleshooting-compatibility-problems-with-library-content.html
https://www.chiefarchitect.com/support/article/KB-02772/troubleshooting-library-download-issues.html
You may want to contact tech support on this one though because your user library might be corrupt.
It worked! also successfully imported your files as well! yay! i also relocated the folders beforehand. thank you alot!
