Construction Lines Not Really Useful
KristjanM
I do like to use construction lines to locate important junctions. The snapping behavior in Chief doesn't seem to help. If I move a wall to align with a construction line, the wall snaps to the outside layer of the wall. I cannot make the wall's main layer align with the construction line which is what I want. Am I missing something here?
I can't say I've ever moved walls to Const Lines, I've always drawn the walls over the lines so I've never experienced this. Certainly seems it should snap/bump off the line the handle is on. I'd report this as a bug to Support.
In the meantime, Point to Point Move should help move the walls onto those lines.
No you're not. That's how the construction lines work, although I agree with you. The behavior for objects to bump up against construction lines should be different for walls. It seems logical that we'd want the walls to snap to construction lines using the exterior of the walls' main layer.
Because construction lines aren't a requirement for home plans, I only use them in large and complex projects where they will provide an obvious benefit to myself and those using the plans. Where I do find construction lines helpful is as reference lines to locate a foundation step (for example) in plan and elevation / section view. I usually have them on a reference layer that only displays in my working views and not my final plans.
6 minutes ago, Renerabbitt said:
Go to Edit/Default Settings/Walls/General Wall/ and change the option resize about to main layer outside.
This is optionally necessary; Main Layer Outside is the default so if you've never messed with that setting then you're good.
7 minutes ago, Renerabbitt said:
then turn off bumps (f11)
This hasn't been a default Hotkey in quite some time.
But, yes, Edit>Snap Settings> Bumping and Pushing, then it should snap as desired.
AND if you find yourself needing to toggle it often, Tools> Toolbars and Hotkeys> Customize Hotkeys and set it to something like F11.
10 minutes ago, Renerabbitt said:
don't listen to these know-it-alls :D
you're one to talk ;)
Yes, point to point absolutely works. Thanks.
Walls are already set to outside main layer. With bump on, wall snaps to outside of wall, not outside of main layer. With bump off, wall doesn't snap at all.
Looks like point to point wins for the moment.
Just tried it both ways, object snaps on and off. Wall doesn't snap either way. Curious.
Well, the wall does snap but it is very finicky. Works about one in five times. Changed my pixel snap distance to 30 and now the snap shows up. I had it set at 10 which was obviously set too low. My issue is solved I think. Thanks to all for your help.
I find the construction lines helpful in defining load paths. The reviewers seem to appreciate them also.  The engineers have a better point of references also.  Clients can use them as a way to let me know where to look.
