JKEdmo Posted July 26, 2024 Share Posted July 26, 2024 (edited) Good morning, I'm trying to model this double sink vanity as one base cabinet: I've gotten this far, but am struggling a bit with the 2 sinks and toe kick: Have a couple of questions: 1) How do I place 2 sinks in the countertop? Seems to default to one smack in the middle. 2) How to do an open cabinet base (no kick panel) so that you can see the tile wall base beyond? Thanks again, Jim DOUBLE SINK VANITY.plan Edited July 26, 2024 by JKEdmo Added PLAN file Link to comment Share on other sites More sharing options...
Solution DBCooper Posted July 26, 2024 Solution Share Posted July 26, 2024 Try placing the sinks into the floor plan by themselves and then dragging them on top of the cabinet. You could also use two cabinets but personally I prefer the separate sinks. See if using cabinet "feet" work better than using a toekick. Link to comment Share on other sites More sharing options...
sweethomedesign Posted July 26, 2024 Share Posted July 26, 2024 i drop the second sink on the floor and drag it on the counter. keep sink top height as required. see att. file 656591496_DOUBLESINKVANITY.plan Link to comment Share on other sites More sharing options...
JKEdmo Posted July 26, 2024 Author Share Posted July 26, 2024 4 hours ago, DBCooper said: Try placing the sinks into the floor plan by themselves and then dragging them on top of the cabinet. Thanks! Link to comment Share on other sites More sharing options...
GaryOhmer Posted July 27, 2024 Share Posted July 27, 2024 draw 31" cabinet - uncheck flat sides and flat back in toe kick - in accessories select cabinet foot style you want - place sink - change doors to draws - copy and block together Link to comment Share on other sites More sharing options...
