Elliot Posted July 23, 2024 Share Posted July 23, 2024 I am working in X16 but I had the same problem in X15. I draw a house, with Exterior-6 walls for exterior walls. Interior 4 and Interior 6 for interior walls. I have hardi siding assigned as the cladding of the exterior 6 walls and drywall for interior side. But CA keeps putting the hardi on BOTH sides of the wall. Now its putting hardi on both side of the interior 4 walls. I don't know it until I look at a 3d or wall elevation. I checked my defaults for walls and they show drywall on the interior of the exterior walls and drywall on both sides of an interior wall. In the past the only way to fix it was to delete the wall and create a new wall but I am hitting my frustration limit over this now. Please tell me I am doing something wrong and not that CA has a serious glitch. Link to comment Share on other sites More sharing options...
glennw Posted July 23, 2024 Share Posted July 23, 2024 Can you post the plan. Link to comment Share on other sites More sharing options...
tundra_dweller Posted July 23, 2024 Share Posted July 23, 2024 The only time I've had unexpected wall material issues was user error, usually caused by using the material painter. If I had to bet I would say your drywall material got inadvertently sprayed with your siding material and the scoping for the material painter was set to plan or floor. It took me many years to quit using the material painter on walls and use the wall types or material regions to change up materials instead. Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 23, 2024 Share Posted July 23, 2024 I have seen CA do this unexpectedly, but only for an outside wall. I posted the issue last year. I did not do any wall spray painting. It seemed to occur under the condition of breaking an exterior wall, and then drawing in a new one. For instance, creating a bump in/out. If you go to the materials on that wall you will likely see the errant material. You can just remove it or set it to the default I put in a request to CA that if they are going to change the material, to show a message box informing the user Link to comment Share on other sites More sharing options...
Elliot Posted July 24, 2024 Author Share Posted July 24, 2024 Here is the plan. The hardi is fine on the exterior and shows drywall on the interior in other parts of the house. But in the master bathroom and bedroom, it shows hardi on the interior. thank for the help. Gustafson remodel.plan Link to comment Share on other sites More sharing options...
JKEdmo Posted July 24, 2024 Share Posted July 24, 2024 Elliot, Your interior wall surface was overriden to Artic White: Change it back to Default Drywall: The result: Jim 2 1 Link to comment Share on other sites More sharing options...
