gelbuilding Posted July 16, 2024 Share Posted July 16, 2024 Dont understand why, when i change the layer colour it won`t change. This is a imported dwg drawing and one of the layers is yellow. I have changed to blue as shown below, though the layer is still yellow. Cannot find anything on the forum. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 16, 2024 Share Posted July 16, 2024 13 minutes ago, gelbuilding said: Dont understand why, when i change the layer colour it won`t change. This is a imported dwg drawing and one of the layers is yellow. I have changed to blue as shown below, though the layer is still yellow. Cannot find anything on the forum. if you open the polyline up what shows on this panel: Link to comment Share on other sites More sharing options...
gelbuilding Posted July 16, 2024 Author Share Posted July 16, 2024 Thanks, mate it is yellow. Link to comment Share on other sites More sharing options...
Mark3D Posted July 19, 2024 Share Posted July 19, 2024 But is the box ticked as it won’t change if not Link to comment Share on other sites More sharing options...
DBCooper Posted July 20, 2024 Share Posted July 20, 2024 If something doesn't change color when the layer color is changed, then it either means it is not using the layer you think it is, or you are not using the layer set you think you are, or the object is set to not use the layer color ("by layer" is unchecked). For the first two, the ALDO will show you the layer settings for the current layer set. For the last, just looking at the line style page will tell you. There are other more obscure cases I have seen but they are much less likely. Link to comment Share on other sites More sharing options...
