Double Wall Opening Question
JKEdmo
Hello,
I'm trying to get two window openings to form at a deep double wall.
In red below:
I previously defined the fat furred out wall that the windows sit in as one wall definition.  However, that created a wall cleanup issue as the wall turned the corner plan right near the 1'-0" dimension.
Soooo, I thought I'd be clever and try two separate walls, but cannot seem to get the double wall opening to work.
Any tips would be appreciated.
Thanks once again,
Jim
2 hours ago, JKEdmo said:
Hello,
In red below:
Jim
Hi Jim,
Try this out.  Take a look at the wall definitions.
Doug
Double wall.plan
2 hours ago, Michael_Gia said:
Why not just define one giant wall?
Pretty sure if you created it the way he intends, (2x6, air gap, 2x4), the return on the right where it reduces into a normal 2x6 framed wall is gonna be funky.
Doug's furred wall w/ air gap is likely to build and frame the cleanest.
That was the problem I was running into.  Doug's solution is working pretty well.  Although I'm getting double window shutters!
That said, I'd like to try Michael's suggestion to see if that works too.  I could see showing the air gap as a Cad block.
On deadline right now -- I'll circle back to this.
Once again, thanks for all help!
Jim
