JKEdmo Posted May 7 Share Posted May 7 Hello, I'm trying to get two window openings to form at a deep double wall. In red below: I previously defined the fat furred out wall that the windows sit in as one wall definition. However, that created a wall cleanup issue as the wall turned the corner plan right near the 1'-0" dimension. Soooo, I thought I'd be clever and try two separate walls, but cannot seem to get the double wall opening to work. Any tips would be appreciated. Thanks once again, Jim Link to comment Share on other sites More sharing options...
Doug_N Posted May 7 Share Posted May 7 2 hours ago, JKEdmo said: Hello, I'm trying to get two window openings to form at a deep double wall. In red below: I previously defined the fat furred out wall that the windows sit in as one wall definition. However, that created a wall cleanup issue as the wall turned the corner plan right near the 1'-0" dimension. Jim Hi Jim, Try this out. Take a look at the wall definitions. Doug Double wall.plan Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 7 Share Posted May 7 12 hours ago, JKEdmo said: I'm trying to get two window openings to form at a deep double wall. Why not just define one giant wall? (like in the bottom of the image) Link to comment Share on other sites More sharing options...
TeaTime Posted May 7 Share Posted May 7 2 hours ago, Michael_Gia said: Why not just define one giant wall? Pretty sure if you created it the way he intends, (2x6, air gap, 2x4), the return on the right where it reduces into a normal 2x6 framed wall is gonna be funky. Doug's furred wall w/ air gap is likely to build and frame the cleanest. Link to comment Share on other sites More sharing options...
JKEdmo Posted May 7 Author Share Posted May 7 13 minutes ago, TeaTime said: the return on the right where it reduces into a normal 2x6 framed wall is gonna be funky. That was the problem I was running into. Doug's solution is working pretty well. Although I'm getting double window shutters! That said, I'd like to try Michael's suggestion to see if that works too. I could see showing the air gap as a Cad block. On deadline right now -- I'll circle back to this. Once again, thanks for all help! Jim Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 7 Share Posted May 7 @TeaTime @JKEdmo I added a stud on the interior and a stud in the main layer of the wall. This is how it frames... Link to comment Share on other sites More sharing options...
