Larry_Sweeney Posted May 6, 2024 Share Posted May 6, 2024 Is there a simple way to eliminate the "green" grass reflections from the exterior unto interior surfaces when using PBR. What I usually do now is to turn off the terrain layer? I don't use PBR much and it seems almost every time I do I run into this problem. There must be a simple solution to this problem. Link to comment Share on other sites More sharing options...
MPDesign Posted May 7, 2024 Share Posted May 7, 2024 Hi Larry, Have you tried to turn off refraction? Not sure if that alone will fix the issue. Try using a backdrop outside also. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 7, 2024 Share Posted May 7, 2024 23 hours ago, Larry_Sweeney said: There must be a simple solution to this problem It's your very green and shiny background with that horrible out of the box grass. Experiment with different backgrounds. Try the "Cloudy Sunset" from the Chief Bonus catalogue just to see the effect. With a dark background like that one you get a lot less interference with light bouncing around on the inside. If it's too dark on the inside you can increase exposure and light intensity. It's always easier to increase brightness than to darken an over lit scene. Link to comment Share on other sites More sharing options...
Designers_Ink Posted May 7, 2024 Share Posted May 7, 2024 Try lowing your sunlight level to about 1000 and see if that helps Link to comment Share on other sites More sharing options...
