Low DPI layout printing
DanielleDubuc
Hi,
When I send a layout to the printer I get a warning telling that "Printer DPI value is low: 96 DPI". When I try to modify the DPI value, there is nothing else thant 96 in the drop down menu.
But when I send the plan file of the same drawing to the same printer, I get  600 DPI.
Can someone tell me if there is a way to set the layout printing to a higher DPI?
Thanks in advance
11 hours ago, MPDesign said:
Hi Danielle,
Try using "Chief Architect save as PDF" in the printer dropdown.
then print the pdf to your printer.
This is a good suggestion Michael, it's what I currently do. But I would really like to print right from the layout and save a little time. :)
Thanks  for the suggestion.
8 hours ago, SHCanada2 said:
that is interesting, I would submit that to CA, one would think the available DPI would not be contingent on layout vs plan
SHCanada2, I will do that. Thank you! :)
Can anyone tell me where I can find the email address for the tech support please. I've been looking for it but coudn't find anything. Or else, is ther any way I could tag the tech support on this post?
Thanks in advance!
