tantrim Posted March 18, 2014 Share Posted March 18, 2014 I am working on an old house that has some arched/barreled ceilings and would like to draw them in so our drawings reflect what they currently have. I could use some help with the how-to. Link to comment Share on other sites More sharing options...
VHampton Posted March 18, 2014 Share Posted March 18, 2014 The easiest method would be to take a cross section of the room. Draw an arch (barrel) using the CAD tools. Convert it to a molding polyline with a thickness of say 1" times whatever the length of the room is. Link to comment Share on other sites More sharing options...
dshall Posted March 18, 2014 Share Posted March 18, 2014 The easiest method would be to take a cross section of the room. Draw an arch (barrel) using the CAD tools. Convert it to a molding polyline with a thickness of say 1" times whatever the length of the room is. Now ain't that a clever solution. I like it. Methods for building barrel arch: -ceiling plane -psolid -2d molding am I forgetting another method? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 18, 2014 Share Posted March 18, 2014 I also like it if you don't need the framing. Link to comment Share on other sites More sharing options...
dshall Posted March 18, 2014 Share Posted March 18, 2014 I also like it if you don't need the framing. The beauty of the pmolding is it auto gives you both sides of the drywall whereas the poly solid does not Link to comment Share on other sites More sharing options...
CJSpud Posted March 19, 2014 Share Posted March 19, 2014 Scott: The beauty of the pmolding is it auto gives you both sides of the drywall whereas the poly solid does not You could make your PL solid look just like a sheet of drywall if you wanted to take the time to do it. Link to comment Share on other sites More sharing options...
