Cadwork22 Posted April 7, 2024 Share Posted April 7, 2024 My client wants to do a single slope .5/12 from bottom to top. As you can see there is an angled wall on the left, so if I did a squared roof plane, is there a way to cut it off at the angled wall? Link to comment Share on other sites More sharing options...
Gawdzira Posted April 7, 2024 Share Posted April 7, 2024 In plan view, just grab the desired corner and move it. Link to comment Share on other sites More sharing options...
Cadwork22 Posted April 7, 2024 Author Share Posted April 7, 2024 nice thanks Link to comment Share on other sites More sharing options...
Cadwork22 Posted April 8, 2024 Author Share Posted April 8, 2024 If I can't get this exact is there any way to cut the roof plane like in AutoCAD? Link to comment Share on other sites More sharing options...
DBCooper Posted April 8, 2024 Share Posted April 8, 2024 You can use polyline subtraction if you want to cut out part of a roof plane. In the example above though, I would probably use the make parallel tool instead. Link to comment Share on other sites More sharing options...
glennw Posted April 8, 2024 Share Posted April 8, 2024 You could also use auto roofs to do that roof. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted April 8, 2024 Author Share Posted April 8, 2024 I'm new to the make parallel tool, I think it's what needs to be used here, see attached, I need to bring down the top vertex, and cut off the triangle at the 60 ft mark. Thanks Link to comment Share on other sites More sharing options...
glennw Posted April 8, 2024 Share Posted April 8, 2024 Break the edge of the sloping roof plane at the 60' mark and then drag the vertex down. It is worth saying again...use auto roofs. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted April 8, 2024 Author Share Posted April 8, 2024 Thanks, it worked, sometimes auto roofs doesn't work and creates weird roof plans, so I have to go custom. Thanks again. Link to comment Share on other sites More sharing options...
