DIYJon Posted April 6, 2024 Share Posted April 6, 2024 As you can see in this image that I've ray traced, the tops of the doors, the recessed lights, the ceiling fan...they all have a bright glow to them. If I turn off the sunlight, this goes away. What could be causing this? Link to comment Share on other sites More sharing options...
ericepv Posted April 6, 2024 Share Posted April 6, 2024 This is often caused by not having a roof over the room. Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 7, 2024 Share Posted April 7, 2024 you could also reduce the sunlight intensity to 1500. I think the default is 100 000 Link to comment Share on other sites More sharing options...
Kbird1 Posted April 7, 2024 Share Posted April 7, 2024 4 hours ago, ericepv said: This is often caused by not having a roof over the room. Yes a roof or second story, I suggest making your SOP to add an Auto Foundation and Auto Roof to every build , Chief's "Lighting" engine needs them to calculate how the Light "bounces" around the scene. At times you may c=see the opposite effect and light bleeding under furniture and Cabinets hence the auto foundation..... M. Link to comment Share on other sites More sharing options...
