Glass wall with Mullians/grid
Cadwork22
Go to solution Solved by ericepv,
Select your CAD lines and then make them a CAD block.(on lower toolbar) then click on the window glass. Once you do this, the load mullions button will appear on the lower toolbar.
Follow these steps:
  • Draw your desired mullions on the window using CAD lines
  • Select the CAD lines and make them a CAD bock
  • Then click on the glass and the load mullions tool will appear on the lower toolbar
  • Click on the load mullions button
The tool to create a custom window muntin only works on windows...not "glass" walls. That is why Gene suggested the wall material region tool.
Take a back clipped elevation of the glass wall. Click the wall tool. You should see the wall material region tool. If you double click this tool it'll bring up a dialogue so you can edit what the material will be....and whether to cut the parent layer.
  • Solution
Try drawing a regular wall (you can make it narrow) and then install a large window with a very thin frame. You can then add your mullions with the standard tools.
Pic of glass wall quickly done doodled with material regions to mock up mullions.  You can see the extents of the wall.
The OP might better had described his situation as a framed curtain wall, in which case the solution is done better with windows and mullions.  The way he described it made me think of some super modernistic thing done with huge panels of sheet glass.  Like some 100 million dollar folly built on a seafront lot way out past East Hampton.
