cbucks Posted February 21, 2024 Share Posted February 21, 2024 Interpolating can take about minute or two everytime I make a chance Curious if there are anyways to speed up things I should look for etc? Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 21, 2024 Share Posted February 21, 2024 Interpolating what? Link to comment Share on other sites More sharing options...
TeaTime Posted February 21, 2024 Share Posted February 21, 2024 I'm guessing terrain. If so, check terrain specification and try lowering Surface Smoothing and/or Surface Triangle Count. Could also be something in your terrain causing overly complex interpolation, but that would take some actual investigation, so we'd need to see a plan file. Link to comment Share on other sites More sharing options...
DBCooper Posted February 22, 2024 Share Posted February 22, 2024 I would bet that you did something in your terrain that is making the program work really hard. Without the plan, I couldn't tell you what. You could also turn off auto rebuild for the terrain but that might just mask the problem by making it slightly less annoying. Link to comment Share on other sites More sharing options...
