Have driveway elevation set to 0', set floor to 0' but floor showing below terrain
cbucks
31 minutes ago, cbucks said:
Hi Eric the terrain should be set to 0', with the ground floor say 3" or so higher than grade. Am I checking this in the right spot?
If you want the subfloor 3" above the terrain then set the sub floor to 0 and terrain to -3 and if you are using the subfloor as your reference point then set the offset to 0 on the terrain specifications and all your inputs will make sense.
