cbucks Posted February 9, 2024 Share Posted February 9, 2024 I am having a problem where I have driveway elevation set to 0', set floor to 0' but floor showing below terrain. Seems like there is a check or something I have set wrong Link to comment Share on other sites More sharing options...
ericepv Posted February 9, 2024 Share Posted February 9, 2024 Where is your terrain set relative to the sub-floor of the house? Link to comment Share on other sites More sharing options...
cbucks Posted February 9, 2024 Author Share Posted February 9, 2024 Hi Eric the terrain should be set to 0', with the ground floor say 3" or so higher than grade. Am I checking this in the right spot? Link to comment Share on other sites More sharing options...
Mark3D Posted February 9, 2024 Share Posted February 9, 2024 Upload your plan file to get quick answers Link to comment Share on other sites More sharing options...
Chopsaw Posted February 9, 2024 Share Posted February 9, 2024 31 minutes ago, cbucks said: Hi Eric the terrain should be set to 0', with the ground floor say 3" or so higher than grade. Am I checking this in the right spot? If you want the subfloor 3" above the terrain then set the sub floor to 0 and terrain to -3 and if you are using the subfloor as your reference point then set the offset to 0 on the terrain specifications and all your inputs will make sense. Link to comment Share on other sites More sharing options...
