Jambruins Posted February 5, 2024 Share Posted February 5, 2024 Chief automatically puts double floor joists under partition walls above even if they are non-load bearing. Is there a way to change this so double joists are not created? Link to comment Share on other sites More sharing options...
robdyck Posted February 5, 2024 Share Posted February 5, 2024 Double click a wall (or select all walls), go to Structure>Framing> uncheck Insert Floor Framing Below Link to comment Share on other sites More sharing options...
GeneDavis Posted February 5, 2024 Share Posted February 5, 2024 Shame there's no setting in framing defaults. There oughta be, and leave the user the option to do it at the wall if wanted. Link to comment Share on other sites More sharing options...
SNestor Posted February 6, 2024 Share Posted February 6, 2024 In your template plan...just open your interior walls and on the structure tab, uncheck "Insert Floor Framing Below". Save your template. Then, when you draw new plans...Chief won't automatically place joists under your interior walls by default. You can then open a specific interior wall and check the box if you do want a double joist under it. 2 Link to comment Share on other sites More sharing options...
