cbucks Posted January 31, 2024 Share Posted January 31, 2024 Sorry I'm a new b and may be doing this wrong but if I have two structures on a site plan is there a way I can set the floor defaults for each structure? Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 31, 2024 Share Posted January 31, 2024 Not that I know of. I will select the rooms in the second structure and set their heights. Roofs, if I remember correctly needed to be adjusted as well for height off plate.. Link to comment Share on other sites More sharing options...
glennw Posted January 31, 2024 Share Posted January 31, 2024 I do something similar. Draw the first structure using the defaults. Draw the second structure as one big room following the external wall if possible. Edit the heights (take note of the Absolute and Relative heights) for the second structure and divide it up into your rooms. Roofs should all work as normal. Link to comment Share on other sites More sharing options...
cbucks Posted January 31, 2024 Author Share Posted January 31, 2024 Thanks is there a key command to select all rooms? Link to comment Share on other sites More sharing options...
DBCooper Posted January 31, 2024 Share Posted January 31, 2024 Quote Thanks is there a key command to select all rooms? You could use match properties or marque select similar. Quote if I have two structures on a site plan is there a way I can set the floor defaults for each structure? You could also put them in different plans and then use reference display to see them both. Link to comment Share on other sites More sharing options...
