Walls Not Aligning
Ed_Orum
I am trying to align the upper wall, a pony wall, with the lower wall, a foundation wall.
I have all walls set to align to the main layer.
When I dimension the drawings, the foundation wall and upper walls do not align.
Wha am I doing wrong?  Plan is attached.
Thanks in advance.
Lane
Pool House.plan
Thanks in advance.
Lane
The total thickness of your lower wall (foundation) is 8" but your pony wall (lower section) is 8 15/16".
2 hours ago, Ed_Orum said:
Yes, but what difference does the total wall thickness make when all walls are set to align on the main layer outside?
Your problem appears to be in the wall properties and your default settings. This article from the Knowledge base explains it in detail https://www.chiefarchitect.com/support/article/KB-00658/specifying-which-wall-layer-exterior-dimensions-locate.html
I assume you're using Automatic Dimensions since there is no problem manually dimensioning to the same layer as the foundation wall.
Check your settings, Automatic Dimensions obey the settings in the Dimension Default, which in your case is set to dimension to the Wall Dimension Layer:
1221913928_ScreenShot2024-01-29at9_58_04AM.thumb.png.5599f65c1c646991e96517d66908a82d.png
...as set in the Wall Specifications > Wall Type Definitions > Wall Properties:
1939984920_ScreenShot2024-01-29at9_50_46AM.thumb.png.1fef09d1c42f9faa24fcaf3c991d6392.png
