SusanC Posted January 24, 2024 Share Posted January 24, 2024 Hi, I downloaded a .skp file from a brand that I've downloaded from before (successfully), but this particular object came with a huge bounding box. I opened up the dialog box and found the place to adjust the size of the bounding box, but haven't been successful in fixing the issue. Also, I'm not able to get a thumbnail to generate from this object in my library. Suggestions? Thanks! Susan Link to comment Share on other sites More sharing options...
TeaTime Posted January 24, 2024 Share Posted January 24, 2024 Wow! I'd guess that model has something off to the side that's causing it to behave like this. Maybe some origin marker or something. I'd say the model needs fixing, because that'll fix both of these issues. I don't think there's any way to force the Preview to behave differently. But aside from that the Bounding Box should be editable on the Advanced Sizing panel, you'll likely have to put in a lot of negative values. It'll help to have the Show Bounding Box preview option on. Link to comment Share on other sites More sharing options...
SusanC Posted January 24, 2024 Author Share Posted January 24, 2024 Thank you TeaTime. No luck and I think it's something the company needs to fix on their end, but I was able to find a work around and get the object to work well enough for the time being. Link to comment Share on other sites More sharing options...
robdyck Posted January 24, 2024 Share Posted January 24, 2024 Susan, can you provide a link to the model on 3d warehouse? I'd like to see if I can make the correction. Link to comment Share on other sites More sharing options...
SusanC Posted January 25, 2024 Author Share Posted January 25, 2024 Hi Robert, Here is the link to the object. It is on the manufacturer's website. https://fittingscollection.com/collections/wall-shelving/products/double-wall-shelf-3 Thank you for giving it a go! Susan Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 25, 2024 Share Posted January 25, 2024 10 minutes ago, SusanC said: Hi Robert, Here is the link to the object. It is on the manufacturer's website. https://fittingscollection.com/collections/wall-shelving/products/double-wall-shelf-3 Thank you for giving it a go! Susan there is typical a surface at the outer bounds of the bounding box, this one was easy to spot. Here you go: Double wall shelf-3 tier.calibz Link to comment Share on other sites More sharing options...
SusanC Posted January 25, 2024 Author Share Posted January 25, 2024 5 hours ago, Renerabbitt said: there is typical a surface at the outer bounds of the bounding box, this one was easy to spot. Here you go: Double wall shelf-3 tier.calibz 712.98 kB · 2 downloads Wow! Thank you @Renerabbitt I went back in and zoomed way in to see a little round circle on the far edge of the box. Is that what you found and deleted? May I ask how you deleted it? I don't seem to be able to isolate it from the rest of the box. I'd just like to know for future reference. Thanks. Link to comment Share on other sites More sharing options...
robdyck Posted January 25, 2024 Share Posted January 25, 2024 Hi Susan, yes, that little circle in the bottom right hand corner is a surface. In a 3d view, you can delete the surface and then use the convert to symbol tool. delete surface.mp4 1 Link to comment Share on other sites More sharing options...
robdyck Posted January 25, 2024 Share Posted January 25, 2024 This symbol has been assigned to cabinet, shelving layer and has the materials assigned as well as a few other adjustments making it ready to go. DOUBLE WALL SHELF - 3 TIER.calibz Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 25, 2024 Share Posted January 25, 2024 26 minutes ago, robdyck said: This symbol has been assigned to cabinet, shelving layer and has the materials assigned as well as a few other adjustments making it ready to go. DOUBLE WALL SHELF - 3 TIER.calibz 543.26 kB · 0 downloads Apparently we're fighting now, my previous symbol wasn't good enough? Fine Here's one with a more realistic base and custom texture, set to include in schedule as shelf on the cabs shelf layer with options set to mount to wall. I'm not petty you're petty Double wall shelf-3 tier.calibz 1 Link to comment Share on other sites More sharing options...
robdyck Posted January 25, 2024 Share Posted January 25, 2024 1 minute ago, Renerabbitt said: Apparently we're fighting now, my previous symbol wasn't good enough? Ha! I felt stupid, I posted that symbol and then noticed you had already done that! No symbol duel intended! 1 Link to comment Share on other sites More sharing options...
SusanC Posted February 6, 2024 Author Share Posted February 6, 2024 Thank you @robdyck and @Renerabbitt for the tutorial on how to get rid of a stray surface using 3d view! Really appreciate your help. 1 Link to comment Share on other sites More sharing options...
