Closing tiled views
Ed_Orum
I probably should have learned how to do this back in the 90's.
When I use the "tile window" buton, and there are two windows open, one for the plan view and one for the layout view,  how do close the layout view without closing the layout itself?
Thanks in advance.
Lane
The layout view is the layout itself, so you can't close the layout window without closing the layout itself.
If you double click in the title bar of the plan window, the plan window will maximise and hide the layout window.
You will then be able to click on the various tabs to switch between plan and layout while they are maximized.
Not really closing the layout, but the same effect.
You can also switch between windows using the Project Browser.
