KnotSquare Posted January 5, 2024 Share Posted January 5, 2024 In this screen shot, the red and cyan areas should not have siding behind them as they are forward of each wall behind it. The red is out front of the wall at the main roof and the bay is easier to see, but in front of the lower gable wall. It seems that it was the case in the past that exterior materials were trimmed by such constructed objects out front. I do have a special wall type, complying with 2021 IECC standards. Link to comment Share on other sites More sharing options...
KnotSquare Posted January 5, 2024 Author Share Posted January 5, 2024 @solver Are you suggesting that I replace the wall area under the gable with glass block? I see where that would help with siding count, but won't it then frame incorrectly as in no stud wall? Mark Link to comment Share on other sites More sharing options...
KnotSquare Posted January 5, 2024 Author Share Posted January 5, 2024 I will toss together a quick video. Link to comment Share on other sites More sharing options...
KnotSquare Posted January 5, 2024 Author Share Posted January 5, 2024 @solver YouTube says it will be ready in a bit, maybe 20 minutes. I will repost this link when it is ready as well to embed the video. https://youtu.be/xAwioM77_E0 Link to comment Share on other sites More sharing options...
KnotSquare Posted January 5, 2024 Author Share Posted January 5, 2024 @solver Done processing. Link to comment Share on other sites More sharing options...
GeneDavis Posted January 5, 2024 Share Posted January 5, 2024 Try making a wall type same layers except no siding, which will be your wall tupe for "lower wall type if split . . ." Link to comment Share on other sites More sharing options...
mthd97 Posted January 5, 2024 Share Posted January 5, 2024 Hi, Have you tried using a “Wall Material Region” and see how that reflects in the ML ? See if it is possible ti give it a negative value in order for it to deduct from the siding ? If that doesn’t work then you could leave that gable with no siding and use the WMR to create siding for that gable. Please see this video on FMR & WMR. I am sure you will figure it out. https://www.youtube.com/watch?v=Vxvwbt_R7_g Link to comment Share on other sites More sharing options...
KnotSquare Posted January 5, 2024 Author Share Posted January 5, 2024 @mthd97 Checking out the video link now. What did you mean by. "See if it is possible ti give it a negative value in order for it to deduct from the siding ?" realizing the question marks were likely referencing a concept, not a tried and true method. Negative space or thickness? Link to comment Share on other sites More sharing options...
KnotSquare Posted January 5, 2024 Author Share Posted January 5, 2024 I use material regions to paint rooms, etc., but have no idea how it will affect the amount of siding and/or exterior insulation is calculated. I will post back here if I learn anything new while trying to figure this out. Mark Link to comment Share on other sites More sharing options...
Mark3D Posted January 5, 2024 Share Posted January 5, 2024 3 hours ago, solver said: I may not understand. Try this Eric nows his stuff it seem like it should work you just need a new wall with out sidding then change to that wall with dropdown box Link to comment Share on other sites More sharing options...
KnotSquare Posted January 5, 2024 Author Share Posted January 5, 2024 What I learned from the negative space experiment using a Wall Material Region... @Mark3D Eric usually does. I did not get what he was trying however. I will try that next if I can figure out what he did. 1 Link to comment Share on other sites More sharing options...
KnotSquare Posted January 5, 2024 Author Share Posted January 5, 2024 @solver Mark just copied what you had. I was not paying attention. Instead of glass block I need a wall type of framing, drywall inside, sheathing outside as the lower wall. Look like the solution. On to that now. Thanks Eric. You do make us think it through... Mark Link to comment Share on other sites More sharing options...
mthd97 Posted January 5, 2024 Share Posted January 5, 2024 3 hours ago, KnotSquare said: @mthd97 Checking out the video link now. What did you mean by. "See if it is possible ti give it a negative value in order for it to deduct from the siding ?" realizing the question marks were likely referencing a concept, not a tried and true method. Negative space or thickness? Hi Mark. I didn’t mean that the WMR would cut your siding out. I meant that if it had a negative value in the ML, so that it would deduct from the total area of your siding. My other suggestion was to have no siding at all, on that particular Gable as others have suggested above. Then use a WMR to draw the siding that you need in manually and look for it in the ML calculations. Anyway you have figured it out by the looks ? Yes it would be good if we had a method of cutting out materials to stop them from making the ML inaccurate. One of the Chief Masters here might have a trick or two up their sleeves, to get that roof that meets that gable to cut out that siding triangle that you do not need ? Link to comment Share on other sites More sharing options...
