KittleDesign Posted November 28, 2023 Share Posted November 28, 2023 I am trying to recreate an existing wood deck ramp (see attached pictures). I have started in on the ramp tool but I haven't figured out how to get the base to be lumber instead of a sloped solid. I wouldn't care if it was still a solid but the bottom was sloped to match the top, that would work for what I am trying to do. I just want to try to use the ramp tool before I resort to having to build it out of polyline solids. I hope I am just missing a check box or setting. Thanks in advance... Jess Link to comment Share on other sites More sharing options...
Solution DBCooper Posted November 28, 2023 Solution Share Posted November 28, 2023 Try this: - check open underneath - set the max thickness - turn off auto heights - set base height to the same as your thickness 1 Link to comment Share on other sites More sharing options...
robdyck Posted November 28, 2023 Share Posted November 28, 2023 I was just typing all of that ↑↑ 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted November 28, 2023 Share Posted November 28, 2023 It would appear as though the ends of your ramp need to be skewed. So your ramp can provide the railing or actually two skinny ramps and then a roof plane can be used for the sloped framing and roof purlins for decking all but a few boards that may need to be p-solids if they don't trim properly. 1 Link to comment Share on other sites More sharing options...
KittleDesign Posted November 29, 2023 Author Share Posted November 29, 2023 17 hours ago, DBCooper said: Try this: - check open underneath - set the max thickness - turn off auto heights - set base height to the same as your thickness Thank you, this did the trick for what I need to show the client. Link to comment Share on other sites More sharing options...
KittleDesign Posted November 29, 2023 Author Share Posted November 29, 2023 16 hours ago, Chopsaw said: It would appear as though the ends of your ramp need to be skewed. So your ramp can provide the railing or actually two skinny ramps and then a roof plane can be used for the sloped framing and roof purlins for decking all but a few boards that may need to be p-solids if they don't trim properly. I agree, this is a better solution to show what is existing (with the skewed ends of the ramp), but in this case I don't need it to be exact. From my understanding this ramp will be torn down and replaced with a different walkway, to go around a new addition to the home. Thank you. Link to comment Share on other sites More sharing options...
