ACAaron Posted November 28, 2023 Share Posted November 28, 2023 I'm working with an outside drafter and every time I receive their files, the text boxes are "crunched", making a text box that is supposed to be one line, two kines. I have to open it, then close it and the text goes back to what it was originally supposed to be. This has been an issue for years and if I recall, it has to do with the monitor resolution that the text box was created in. Are there any solutions to this yet? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 28, 2023 Share Posted November 28, 2023 12 hours ago, ACAaron said: This has been an issue for years and if I recall, it has to do with the monitor resolution that the text box was created in. Correct and there is no fix that I am aware of, the only solution is to group select (various methods) all the Text , > Open > and Click Ok to close the DBX again , which causes them all to "refresh" in the current Plan. M. Link to comment Share on other sites More sharing options...
ACAaron Posted December 12, 2023 Author Share Posted December 12, 2023 Quite an annoying thing, you'd like would have been updated by now. Link to comment Share on other sites More sharing options...
Renerabbitt Posted December 12, 2023 Share Posted December 12, 2023 1 hour ago, ACAaron said: Quite an annoying thing, you'd like would have been updated by now. Use regular text instead of rich text Link to comment Share on other sites More sharing options...
para-CAD Posted December 13, 2023 Share Posted December 13, 2023 Sucks that instead of being able to use Rich Text without issue, we have to revert to using plain text or resize the offending RT. Might as well remove RT from the app then. /s The /s means sarrrrrrcasm. We need to laugh more Link to comment Share on other sites More sharing options...
CharlesVolz Posted December 13, 2023 Share Posted December 13, 2023 Toolbars also a problem when using multiple monitors with different resolutions. I have not seen a post on that fix either. Link to comment Share on other sites More sharing options...
