AbeLopez Posted October 27, 2023 Share Posted October 27, 2023 Hi, I'm have trouble exporting my exterior elevations to AutoCAD?23-159 XXX.plan Link to comment Share on other sites More sharing options...
AbeLopez Posted October 27, 2023 Author Share Posted October 27, 2023 23-159 XXX.plan Link to comment Share on other sites More sharing options...
DBCooper Posted October 27, 2023 Share Posted October 27, 2023 Hmm, what kind of problems? Link to comment Share on other sites More sharing options...
AbeLopez Posted October 27, 2023 Author Share Posted October 27, 2023 When I export nothing shows up. Link to comment Share on other sites More sharing options...
BenPalmer Posted October 27, 2023 Share Posted October 27, 2023 It's there, it's just really small because your left camera is waaaay far away. Turn the camera layer off (or move the left camera closer to the model) then export and zoom extents in the importing cad software and you should be good to go. Link to comment Share on other sites More sharing options...
AbeLopez Posted October 27, 2023 Author Share Posted October 27, 2023 I deleted the left camera view, still can't see. Link to comment Share on other sites More sharing options...
BenPalmer Posted October 27, 2023 Share Posted October 27, 2023 Works for me perfectly. What software are you opening it in? Are you using 'zoom extents' (zooming in) to see it once you open it? I open the attached in Autodesk DWG TrueView and then zoom extents and it is there. It won't show up on the screen initially, but will once you 'zoom extents' to get it on the screen. 92613661_23-159XXX.dwg Link to comment Share on other sites More sharing options...
AbeLopez Posted October 27, 2023 Author Share Posted October 27, 2023 Does the front elevation show up for you when you export it? Link to comment Share on other sites More sharing options...
BenPalmer Posted October 27, 2023 Share Posted October 27, 2023 Where you able to export the file and have it show up? Did the floor plan show up for you in the file I sent? (The file I attached was only one level of the floor plan, no elevations, which is done separately). I want to make sure your first issue was solved and that you were able to reproduce it on your own as that will help you with the next step. Once you are able to export the floor plan(s) you want, then do the same things for each elevation or additional floor level you want to export....one at a time. For example, for the front elevation, get the camera view of it that you want and export it the same way. Then repeat for each view/plan you need. So you will end up with multiple cad files. Link to comment Share on other sites More sharing options...
AbeLopez Posted October 27, 2023 Author Share Posted October 27, 2023 Yes, I got the floor plan to show up, but not the elevations. Link to comment Share on other sites More sharing options...
BenPalmer Posted October 27, 2023 Share Posted October 27, 2023 2 minutes ago, AbeLopez said: Yes, I got the floor plan to show up, but not the elevations. Great, read the last paragraph of my previous post for how to get the elevations. Link to comment Share on other sites More sharing options...
KevinWaldron Posted October 27, 2023 Share Posted October 27, 2023 If you export as a 3DWG file. You can get this info.... not all but most...... kw Link to comment Share on other sites More sharing options...
madcowscarnival Posted October 31, 2023 Share Posted October 31, 2023 Did OP ever get this to work? I had a similar problem in that I use dark model space in CAD, and when the CA elevations export, the layers are all assigned a dark color that doesn't display well or at all on my screen. I just ctrl+a to select everything and change it to white lines, also zoom extents as mentioned above. Might be the case here, might be nowhere close, worth a shot though. Link to comment Share on other sites More sharing options...
Planstech Posted December 17, 2023 Share Posted December 17, 2023 That last post is a good point. Along with the fact that it may be very small as far as zoom locations in AutoCad. I go into layers in AutoCad and sort by color and change all the dark colors (I think 18) to yellow so it pops out at me. Something I've tried for awhile is to use a while background in AutoCad. That way all the chief layers colors show up the same. Link to comment Share on other sites More sharing options...
