Framing shows through roofing
Adam_Gibson
Go to solution Solved by Adam_Gibson,
This is in vector view---correct? I believe once you send the view to layout the framing won't show. I know it can be annoying. I usually just turn off those layers if possible in the view I'm looking at if possible. I'll be very happy if someone comes on and says there is a way to fix this.
I sometimes set the material of the roof surface to be about 1 1/8" thick. Then the framing goes away in elevation views.
Might not be the best thing for some situations but so far it has worked for me.
Andy.
