Spell Check in DBX & Layout Labeld Fields
ACADuser
On 8/10/2023 at 4:04 PM, ACADuser said:
Has anyone found a program that will work in DBX fields & Layout label fields to check spelling?
I'm working in Windows 10
Thanks
wwhat would be an  example  of a dbx field that would need spellchecking?
The spell check tool works for layout box labels
1 hour ago, ACADuser said:
The spelling tool does not work for me in layout labels.
Spell check is not available within the DBX but it is at the layout page level when multiple objects are selected. Selecting a single layout box will not trigger the tool.
The easy method is just hit Select All at the layout page, then it checks everything including layout labels.
Now  I wonder why you need 2 layouts to be checked to get the spell checker to work?
Obviously I was asleep when that was covered in class.
My point is that I want the spelling checked in real time when i can correct it immediately.
Thanks for that tip Rene, but global spell check is way overkill for me.
So many slang terms & abbreviations make it tedious. I suppose after using the Learn word feature that would calm down.
I'll keep pushing for a "real time spelling check"
