LisaKobar Posted August 2, 2023 Share Posted August 2, 2023 Does anyone know why walls won't frame correctly on top of my foundation wall? I've tried every setting I can think of and reframed all the walls multiple times...They keep framing into the concrete wall. Any help would be appreciated. Lisa Link to comment Share on other sites More sharing options...
DG1949 Posted August 2, 2023 Share Posted August 2, 2023 Do you have the foundation set to rebuild? Link to comment Share on other sites More sharing options...
LisaKobar Posted August 2, 2023 Author Share Posted August 2, 2023 I do not. I've done too many custom changes to it.... I'll try on a separate file and see if that makes a difference. Thank you! Link to comment Share on other sites More sharing options...
robdyck Posted August 2, 2023 Share Posted August 2, 2023 If you post your plan file or a google drive link / dropbox link, you will have the answer in minutes. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 4, 2023 Share Posted August 4, 2023 is your wall set to default top and bottom wall, then rebuild wall or turn on auto rebuild walls. Link to comment Share on other sites More sharing options...
