deleted post
SkullMesaRanch
Go to solution Solved by robdyck,
Do you have "auto rebuild foundation" turned on?  If not, every time you make a change that would affect your foundation, you would need to manually update your foundation.
If this doesn't help, then I'm not sure I fully understood your questions.  You might need to attach a plan with revised questions.
It looks like your porch room is building a mono slab foundation and your porch railing is building a footing underneath it.  I think these are the "foundation extensions" you are seeing.  Open your porch railings and turn off "foundation wall" and it should look better.
  • 1 month later...
