Renerabbitt Posted June 14, 2023 Share Posted June 14, 2023 This seems like a particular complex bit of code. How do we accumulate totals for custom object fields. The problem as I see it is making sure we are not accumulating every time a publisher changes its reported value...so we have to script in a checksum..maybe through a rescue? or is this some sort of array..how would you approach this? Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 14, 2023 Share Posted June 14, 2023 I use, if available, a unique identifier and an array (could probably use a hash as well). For instance I add up all window areas on an elevation uisng a label in the window, but if the window changes size, one needs to not just add the new area, but replace/remove the old area in the summation. The unique identifier I use is the schedule number, and force the schedule to not duplicate. so if your custom object field is from an object that is "seen" (windows are seen on elevation and plan (asssuming the label is showing), I suppose you could use the same methodology Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 15, 2023 Share Posted June 15, 2023 I use a timer for most things like this. Periodically I clear the hash (don't like using arrays) and then allow all the macros to update the hash and sum the data. Typically I set my timer to about 5 minutes so I'm not updating to often. The macros just skip all processing until the timer has reached the update interval. It's also possible to have a macro that's only displayed on demand to clear the hash. That way you can display it only when you want to force an update. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 20, 2023 Share Posted June 20, 2023 I've tested and used quite a few different methods for this type of thing, but I hated having to manually refresh things or depend on timers, so I recently went back to the drawing board and developed an entirely new system... It remain constantly live, and allows using either a standalone total or a functioning schedule that can be reordered. Its a rather complex system with its own limitations but I love how it works. I don't have a lot of spare time these days but I can offer my services to help set something up or teach you how it works as time permits. If you're interested, I think you have my email. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 20, 2023 Share Posted June 20, 2023 50 minutes ago, Alaskan_Son said: I've tested and used quite a few different methods for this type of thing, but I hated having to manually refresh things or depend on timers, so I recently went back to the drawing board and developed an entirely new system... It remain constantly live, and allows using either a standalone total or a functioning schedule that can be reordered. Its a rather complex system with its own limitations but I love how it works. I don't have a lot of spare time these days but I can offer my services to help set something up or teach you how it works as time permits. If you're interested, I think you have my email. What happen if you edit one of the existing walls? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 20, 2023 Share Posted June 20, 2023 I showed that in the quick GIF clip above unless I’m misunderstanding the question. I both added walls and edited existing walls. Moving existing walls changed the automatically produced foundation walls which also updated accordingly. Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 21, 2023 Share Posted June 21, 2023 interesting ...I think my macro in the label would give similar output, but I think if I remember correctly the label always has to be showing (even if it is teeny tiny) does your total update if you delete the wall, in say,a 3d view,.without going back to the view with the total or a plan view? that is always the limitation I have found ...unable to always trigger a refresh under all conditions...especially the removal.of an object as there is no "on_delete" event that I know of. The CA schedules are oh so close to being able to do this type of thing Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 21, 2023 Author Share Posted June 21, 2023 "How would you approach this" Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 21, 2023 Share Posted June 21, 2023 rene, Joe looks to add things to a hash and then runs timers to add things up (presumably goes through the hash to add applicable fields) I add things to an array via a label, and then have a macro which runs through the array to add them up. The tricky part I have found is accounting for a removal of an object. I have a reset macro on the plan, which it looks like Joe has something similar. So i have two macros below, one in the window label, and one in the pline(elevation area) label then resize add a window: Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 21, 2023 Share Posted June 21, 2023 My problem with using Schedules for this is that I can't specify an area to be in more than one Schedule. Basically I have many closed Polylines all on floor level 1 I want all of them to be in Schedule A some of them in Schedule B some in Schedule C etc. I need to display totals for each Schedule as well as some calculated totals (added, and/or subtracted) Schedules currently just don't have the flexibility I need. Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 21, 2023 Author Share Posted June 21, 2023 2 minutes ago, Joe_Carrick said: My problem with using Schedules for this is that I can't specify an area to be in more than one Schedule. Basically I have many closed Polylines all on floor level 1 I want all of them to be in Schedule A some of them in Schedule B some in Schedule C etc. I need to display totals for each Schedule as well as some calculated totals (added, and/or subtracted) Schedules currently just don't have the flexibility I need. This was the major point of this thread for me, beside trying to learn about how to approach this. From studying Ruby and trying to figure out how it correlates to the nuances in Chief, I have yet to figure out anything that totals without being a huge workaround. I think we are due for a suggestion to Chief no? Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 21, 2023 Share Posted June 21, 2023 12 minutes ago, Renerabbitt said: I think we are due for a suggestion to Chief no? there was a related suggestion earlier this year, which in my view, would solve all sorts of problems Link to comment Share on other sites More sharing options...
