Lighting Adjustments
RobUSMC
Is there a way to adjust the Lumens of a light that have multiple light all at the same time.  I have an LED mirror that has 14 perimeter lights and I would like to decrease them all to a lower lumen all at the same time versus individually.  Im doing these in the library and not in a particular plan so I dont have to change them every time they are used
4 minutes ago, DBCooper said:
I think Rob is showing the X14 and older dialog and Robert is showing the new X15 one.
You're much more observant than I am. I just read the question and saw X15 user in the signature.
I think if you wanted to do this in X14, you could place the light into a blank plan, open a camera view, and use the "adjust lights" tool.  Then you would have to save the light back to the library.  I did not actually try this but it should work and obviously it would be easier with the improved light dialog in X15.
2 minutes ago, RobUSMC said:
IN adjust light you still have to open each individual light and edit however many lights it has
Seems to work for me Rob....... at least with the Chandelier I tried....
I adjusted the Main Fixture Item light Data ( don't expand to show all lights and multi-select)
and it also adjusted the light data for the 3 "lights" on the Light I tried.
