HumbleChief Posted June 10, 2023 Share Posted June 10, 2023 Specifically a GFCI outlet's label to make it more easily read in plan view? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 10, 2023 Share Posted June 10, 2023 The easiest way is to send the Legend to layout at a larger scale, at least that is what I do. Otherwise one would have to export the label block from CAD-CAD Block Management, explode-make larger then reassociate using "CAD Block Management. DJP 1 1 Link to comment Share on other sites More sharing options...
scottharris Posted June 10, 2023 Share Posted June 10, 2023 On 6/10/2023 at 2:48 PM, HumbleChief said: Specifically a GFCI outlet's label to make it more easily read in plan view? Expand You could use the "edit CAD block" tool and resize it. 1 Link to comment Share on other sites More sharing options...
RobUSMC Posted June 11, 2023 Share Posted June 11, 2023 You can edit the electrical label font and text size in the layer display options. Make sure in the symbol dbx under label tab to check Use Object Layer (Whatever Layer you have that symbol on). I have my switches on a layer I named Electrical, Switches. See attached FYI. I have most of my electrical symbols on their own layer such as Electrical, Switches, Outlets, Ceiling Lights, Wall Lights and so on. The reason I do this is when you have all these plus under cabinet rope lights, backsplash outlets and switches, pendants and so on on the same layer such as the default electrical layer and your in a kitchen they are all on top of one another and makes it hard to read on a plan. I send these to individual sheets in my layout. My electrician loves it because its easy to read. That's just how I do it. I'm sure others have their own process too. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted June 12, 2023 Author Share Posted June 12, 2023 Thanks so much for the replies. I see 2 good ways to accomplish the task would like to change the default size but this will do nicely. Link to comment Share on other sites More sharing options...
