wnschoen Posted June 7, 2023 Share Posted June 7, 2023 Is it just me, or is anyone else having a devil of a time getting the object snaps to work in X15? Ever since I upgraded, things don't seem to snap the same. I've played with the defaults and the preferences (by the way, why in the world are angle snaps in a different location/menu than the other snaps)? Anyway, anyone else having issues? I put a ticket into Chief, but that tech said they could not repeat my issue. Thanks, Nate Nate Schoen Bridgewater Consulting LLC (Custom Design Firm) Beaufort, South Carolina www.homesbybridgewater.com / nschoen@homesbybridgewater.com (843) 422-7778 Chief Architect Premier X15 Windows 11 Pro x 64 Intel Core i9013900 w/24 Cores 5.6GHz NVIDIA GeForce RTX 4070 12GB GDDR6X ASUS ProArt Z790-Creator LGA 1700 Motherboard 4x Kingston Fury Renegade 16GB 7200MT/s DDR5 CL38 DIMM (64GB Total) Kingston Fury Renegade 4TB PCIe Gen 40. NVMe M.2 SSD 2x BenQ PD2700U Monitors Link to comment Share on other sites More sharing options...
para-CAD Posted June 7, 2023 Share Posted June 7, 2023 Yes. I use point-to-point move a lot and at least half the time, when I grab an object at an end or corner, once I start moving the object, I notice that the cursor and snap point are not located the same. My cursor will be a slight distance away from my chosen snap point. This results in having to place the object somewhere and retry the P2P move. Also, 3D solids have multiple snap points on a corner, when viewed in 2D. The snap symbol (circle in square), will jump around when the cursor is hovered over the corner. Feels loosely gooses at times. Link to comment Share on other sites More sharing options...
plannedRITE Posted June 7, 2023 Share Posted June 7, 2023 2 minutes ago, para-CAD said: Yes. I use point-to-point move a lot and at least half the time, when I grab an object at an end or corner, once I start moving the object, I notice that the cursor and snap point are not located the same. My cursor will be a slight distance away from my chosen snap point. This results in having to place the object somewhere and retry the P2P move. Also, 3D solids have multiple snap points on a corner, when viewed in 2D. The snap symbol (circle in square), will jump around when the cursor is hovered over the corner. Feels loosely gooses at times. Yes, the point-to-point move issue has driven me nuts for quite a while. I've brought it up in the past but have just been told (can't remember if by chief or other users) "you're moving too fast!" Not a good answer, I sure would like that fixed as well. Link to comment Share on other sites More sharing options...
BenPalmer Posted June 7, 2023 Share Posted June 7, 2023 52 minutes ago, para-CAD said: Yes. I use point-to-point move a lot and at least half the time, when I grab an object at an end or corner, once I start moving the object, I notice that the cursor and snap point are not located the same. My cursor will be a slight distance away from my chosen snap point. This results in having to place the object somewhere and retry the P2P move. Also, 3D solids have multiple snap points on a corner, when viewed in 2D. The snap symbol (circle in square), will jump around when the cursor is hovered over the corner. Feels loosely gooses at times. Similar experience...not satisfied. 1 Link to comment Share on other sites More sharing options...
wnschoen Posted June 7, 2023 Author Share Posted June 7, 2023 I would add that it seems to be an even bigger problem/inconsistent when I am using 3D Objects (like my footers and CMU Block that I draw in CAD and turn into 3D Solids). Thanks. Link to comment Share on other sites More sharing options...
robdyck Posted June 7, 2023 Share Posted June 7, 2023 I sent this issue to TS this week. The response: I believe we may have a case of lost functionality here, and will be contacting our developer department to see if we can have it addressed. CAD LINE SNAP PROBLEM.wmv Link to comment Share on other sites More sharing options...
wnschoen Posted June 11, 2023 Author Share Posted June 11, 2023 That's good. When I contacted Tech Support they 'couldn't replicate my issue'.... hopefully we can all get it fixed. It's kind of a basic CAD thing and really needs to work. Link to comment Share on other sites More sharing options...
para-CAD Posted June 11, 2023 Share Posted June 11, 2023 Robert, Can you update your video link? It goes here in error (see attached) I'll start videoing as I draw and catch when this happens to me. Link to comment Share on other sites More sharing options...
