default layer
BruceKC
1 hour ago, BruceKC said:
I can't figure out how to delete layers that were obviously imported into the template (by accident) from autocad and are now "default layers" in the template.  Can't see them, so can't delete them.
Use ALDO.  BTW if the little red plus sign is there then it is actually being used.
Check your cad blocks.  Maybe when you imported the cad it had some blocks that were imported that are using the layer.  They can still be in the cad block management dialog even when they are not anywhere in the plan.
If you still can't find it, then you should probably post the plan to see if someone is willing to help you look.
