JKEdmo Posted April 9, 2023 Share Posted April 9, 2023 Good morning. Working in X15 and on a remodel where we are opening up an existing stair to an adjacent room. (Note that in screen shots below, the fine dashed red linework is demolition reference display plan as underlay) So, I've got the stair up against a wall with a half-circle starter tread opposite as existing condition: When I delete the stair wall, the second starter tread automatically pops into place: I want to keep the stair to only have a starter tread on one side. Is this doable in X15? When I try the starter tread edit handles, it affects both sides. Thanks again, Jim Link to comment Share on other sites More sharing options...
DBCooper Posted April 9, 2023 Share Posted April 9, 2023 Make your starter tread using a landing instead. 1 Link to comment Share on other sites More sharing options...
MarkMc Posted April 9, 2023 Share Posted April 9, 2023 Room divider works 1 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted April 10, 2023 Author Share Posted April 10, 2023 18 hours ago, DBCooper said: Make your starter tread using a landing instead. Thanks DB! Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted April 10, 2023 Author Share Posted April 10, 2023 17 hours ago, MarkMc said: Room divider works Hi Mark - I couldn't make room divider / invisible work for me. As soon as I made the adjacent wall invisible, the starter tread appears. Jim Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted April 10, 2023 Solution Share Posted April 10, 2023 16 minutes ago, JKEdmo said: I couldn't make room divider / invisible work for me. As soon as I made the adjacent wall invisible, the starter tread appears. A Room Divider set to NOT Invisible will stop the started tread from generating. It may however start casing issues with any wall mounted grab rail. Link to comment Share on other sites More sharing options...
JKEdmo Posted April 10, 2023 Author Share Posted April 10, 2023 4 minutes ago, Alaskan_Son said: A Room Divider set to NOT Invisible Success! Thanks again Mark and Michael. Jim Link to comment Share on other sites More sharing options...
