raltd9245 Posted April 5, 2023 Share Posted April 5, 2023 I'm having trouble making a butt joint corner window . I get a post don't want it. HELP!!! Link to comment Share on other sites More sharing options...
GeneDavis Posted April 5, 2023 Share Posted April 5, 2023 Drag its edge way in there. Don't be shy. You're the boss. Then call the engineer and tell her what you did. 1 Link to comment Share on other sites More sharing options...
VHampton Posted April 5, 2023 Share Posted April 5, 2023 Click on the windows. Go to frame. Uncheck corner post. Do this on both windows. It will disappear. I make many of these, and understand your frustration. Make sure that each window has been pushed far to the corner of the structure. You can do this in plan or in 3D. 1 Link to comment Share on other sites More sharing options...
VHampton Posted April 5, 2023 Share Posted April 5, 2023 3 minutes ago, GeneDavis said: Drag its edge way in there. Don't be shy. You're the boss. Then call the engineer and tell her what you did. Engineers like challenges. : ) 1 Link to comment Share on other sites More sharing options...
raltd9245 Posted April 5, 2023 Author Share Posted April 5, 2023 Much thanks from the OLD man. I'm probably one of the oldest Cheifters atthe young age of 83, Still working every day!!! 5 1 Link to comment Share on other sites More sharing options...
raltd9245 Posted April 5, 2023 Author Share Posted April 5, 2023 Chief nevedr seems to make it easy. I jusyt do not think like they do!!! Link to comment Share on other sites More sharing options...
JacobB Posted April 5, 2023 Share Posted April 5, 2023 If you're using X15, you should be able to change the default window setting to use a miter join or use the object painter to transfer that setting. Note that both windows must be a window type that can miter for the miter to be applied (Fixed, Pass-through, any Casement, Single Hung, and Single Awning). Edit: this is not a dynamic default so changing the setting in the default window will only apply to windows that you create after changing the setting. 1 hour ago, VHampton said: Uncheck corner post. Do this on both windows. In X15 it's now two radio buttons. 37 minutes ago, raltd9245 said: Chief nevedr seems to make it easy. I jusyt do not think like they do!!! There some significant changes to this setting between X14 and X15 and it should be a little easier. I have some more improvements on my list for future versions, but we'll see when I get to them. X14 This option is only enabled if the window you have selected is corner joined and is a type that can corner join. This option is disabled if multiple windows are selected, except for the case where two windows are selected and they are corner joined to each other. It is also a hard setting, meaning this setting forces a corner post or miter join. This also means that this setting can change when the window type changes. X15 This option is enabled whenever you have a window that is corner joined and is a type that can corner join. This options is also enabled for the default window when it is a type that can miter, and when multiple windows are selected and any of them would have this option enabled. It is also a soft setting, meaning that it is applied only when the situation allows a miter join. This setting can also be transferred between windows using the object painter and the style palette. 1 Link to comment Share on other sites More sharing options...
mthd97 Posted April 6, 2023 Share Posted April 6, 2023 3 hours ago, raltd9245 said: Chief nevedr seems to make it easy. I jusyt do not think like they do!!! Oh they make it easier than some other CAD out there but hard to figure out the tricks of the trade. Thanks GD, VH & JB on how to do this trick. Link to comment Share on other sites More sharing options...
VHampton Posted April 6, 2023 Share Posted April 6, 2023 5 hours ago, raltd9245 said: Much thanks from the OLD man. I'm probably one of the oldest Cheifters atthe young age of 83, Still working every day!!! You’re most welcome sir. You are a young many by the way in many regards. My best friend and mentor was working until his latter 90’s. Sharp as ever, and doing the most innovative work of his career as time moved on. He designed many important homes in his early days including the infamous Wave House in Malibu, which inspired the Sydney Opera house designer. Always evolving and endeavoring to be more creative, with an abundance of enthusiasm. As the great Satchel Page once said… (paraphrasing) if you didn’t know how old you were, how old would you think (you were)? Stay young at heart my friend, and my sincere compliments that you’re immersed in practicing your craft with technology. I still miss the long gone hand drafting days, yet if one doesn’t adapt, we get left in the dust. Having said that, it’s an inspiration to see you going strong. All the best. Sincerely, Val 1 1 Link to comment Share on other sites More sharing options...
mthd97 Posted April 6, 2023 Share Posted April 6, 2023 Cheers Val For the master Chiefer above. I like diagrams to make it easier for me. JB is referring to this article. Please see the diagrams and notes in this official link below. https://www.chiefarchitect.com/support/article/KB-00673/creating-corner-windows.html All good. Link to comment Share on other sites More sharing options...
VHampton Posted April 6, 2023 Share Posted April 6, 2023 Thank you as well! Always appreciative for the positive responses. Enjoy the rest of your day. …and yes the new X15 features are simply great. An understatement. The glass corner option for a mitred edge is one of the many many new advancements. (I posted the method pertaining to the earlier release for solution since the original question was geared around previous software capability). That said, Thank you JB and all of your associates at CA. Just when you think the program can’t get any better, it does. Much gratitude for the excellent work. 1 Link to comment Share on other sites More sharing options...
QuickDraw59 Posted Friday at 09:50 PM Share Posted Friday at 09:50 PM I'm late to the party and thank you for getting my 90 degree corner windows to miter/remove post. This plan also has an annoying 75 degree corner that also calls for no post/miter. Chief doesn't seem to want to do this if the corner isn't 90 degrees. Any suggestions? I lowered the balcony parapet/railing in case that was the issue, didn't help. Running Premier X18, newest version download as of this morning. Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted Friday at 09:53 PM Share Posted Friday at 09:53 PM I'm a little curious how y'all detail / what sorta window sched info is on something like this. Anyone care to share? Link to comment Share on other sites More sharing options...
PitMan71 Posted Friday at 10:22 PM Share Posted Friday at 10:22 PM 30 minutes ago, QuickDraw59 said: Any suggestions? Try moving the wall from 75 to 90, let the windows miter and then move the wall back to 75. Make sense? 1 Link to comment Share on other sites More sharing options...
QuickDraw59 Posted Friday at 10:31 PM Share Posted Friday at 10:31 PM My Freakin' Hero! Pulled the Fixed windows to the 90 degree corner (they automatically mulled so what the heck?). Then selected the wall to angle (carefully, one worked better than the other). Selected both windows, opened object, selected miter, bingo. I used 2020 for 25 yrs. My life revolved around outwitting that program daily. I switched to Chief 2 years ago cold turkey. I have a new life goal LOL! Thank you so much. 1 Link to comment Share on other sites More sharing options...
QuickDraw59 Posted Friday at 10:39 PM Share Posted Friday at 10:39 PM Beauty Shot, all three corners. Chef's kiss. 1 Link to comment Share on other sites More sharing options...
