Ed_Orum Posted March 18, 2023 Share Posted March 18, 2023 Today's problem is with windows not showing up in the gable wall. Only the outline of the window shows up. Everything was fine when I last used this file, and I have not opened this file in months, but when I initally drew it, everything was A-OK. The plan is attached, and any help is greatly appreciated. Thanks in advance. Amy-Reggie.zip Link to comment Share on other sites More sharing options...
Solution scottharris Posted March 18, 2023 Solution Share Posted March 18, 2023 If you change your wall structure from 'balloon through ceiling above' to 'automatic' the windows seem to work fine. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted March 18, 2023 Share Posted March 18, 2023 3 hours ago, Ed_Orum said: Today's problem is with windows not showing up in the gable wall. Only the outline of the window shows up. Everything was fine when I last used this file, and I have not opened this file in months, but when I initally drew it, everything was A-OK. The plan is attached, and any help is greatly appreciated. Thanks in advance. Amy-Reggie.zip 3.5 MB · 1 download Haven't downloaded your plan but it sounds like the common occurrence of having 2 walls in the same place , which shouldn't happen but does , eg a attic wall chief has "Forgotten" is still there but the windows don't recognise it. M. Link to comment Share on other sites More sharing options...
GaryOhmer Posted March 18, 2023 Share Posted March 18, 2023 sounds like the gable wall is still there - delete gable wall then ballon frame Link to comment Share on other sites More sharing options...
Ed_Orum Posted March 19, 2023 Author Share Posted March 19, 2023 22 hours ago, scottharris said: If you change your wall structure from 'balloon through ceiling above' to 'automatic' the windows seem to work fine. Yes, that did it! Thanks Link to comment Share on other sites More sharing options...
Ed_Orum Posted March 19, 2023 Author Share Posted March 19, 2023 Thanks for the help everyone! Link to comment Share on other sites More sharing options...
