X7 Can't Delete Auto Exterior Dims Using Delete Objects Auto Dimension.
zowie123
Barry,
If you delete (modify) an auto dimension, it 1) becomes a manual dimension and 2) will then prompt you to turn off the auto dimension with auto-refresh (since it won't refresh your manual dimension).  So, you need to make a decision…
I typically turn the auto dimension off once I have the shell and the openings setup and manually make my adjustments.
