Solution OldBarnDesign Posted January 11, 2023 Solution Share Posted January 11, 2023 I know I've seen somebody on here post a solution to this one, pretty sure it was a @solver or @SNestor video (I'm seen a bunch of them and for the life of me couldn't find the right video on either one of your channels, sorry gents). I've got a porch ceiling where there is a visible gap in height between the soffit and the ceiling. If I recall, this is chief adjusting for the rafter framing, you can see in the DBX is 9 1/4." I've tried playing with both the rafter size and many of the fascia settings and I can't seem to get them to match up. Hopefully this is a softball for somebody, thanks in advance! 1 1 Link to comment Share on other sites More sharing options...
rgardner Posted January 11, 2023 Share Posted January 11, 2023 50 minutes ago, OldBarnDesign said: I know I've seen somebody on here post a solution to this one, pretty sure it was a @solver or @SNestor video (I'm seen a bunch of them and for the life of me couldn't find the right video on either one of your channels, sorry gents). I've got a porch ceiling where there is a visible gap in height between the soffit and the ceiling. If I recall, this is chief adjusting for the rafter framing, you can see in the DBX is 9 1/4." I've tried playing with both the rafter size and many of the fascia settings and I can't seem to get them to match up. Hopefully this is a softball for somebody, thanks in advance! Your soffit Int is following the structure you have a 9 1/4” roof structure and a 7 1/4” gable sun fascia. 2” gap 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 11, 2023 Share Posted January 11, 2023 56 minutes ago, OldBarnDesign said: Hopefully this is a softball for somebody, thanks in advance! On these type of roofs it's best to Make the sub fascia's the same size as the rafter and the Fascia one size bigger. M. 1 Link to comment Share on other sites More sharing options...
OldBarnDesign Posted January 11, 2023 Author Share Posted January 11, 2023 8 hours ago, rgardner said: Your soffit Int is following the structure you have a 9 1/4” roof structure and a 7 1/4” gable sun fascia. 2” gap That did it! Thank you! 1 Link to comment Share on other sites More sharing options...
OldBarnDesign Posted January 11, 2023 Author Share Posted January 11, 2023 8 hours ago, Kbird1 said: On these type of roofs it's best to Make the sub fascia's the same size as the rafter and the Fascia one size bigger. M. Thank you! I've got it logged into my memory now. 1 Link to comment Share on other sites More sharing options...
rgardner Posted January 11, 2023 Share Posted January 11, 2023 49 minutes ago, OldBarnDesign said: Thank you! I've got it logged into my memory now. Glad it helped out. just an fyi and probably the reason someone downvoted your comment above. 1.) It’s considered bad form to mark yourself as the correct answer unless you figured it out on your own and detailed out the response for others. The marking correct answer helps others who have the same question to find the correct answer. 2.) marking the correct answer helps others who are searching to get their answer quickly. 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 11, 2023 Share Posted January 11, 2023 4 hours ago, rgardner said: It’s considered bad form to mark yourself as the correct answer Just a faux pas I think , I think he just marked it solved is all, not that he solved it. M. 2 Link to comment Share on other sites More sharing options...
OldBarnDesign Posted January 11, 2023 Author Share Posted January 11, 2023 It was literally a mis-click. You both helped me solve the problem and I couldn't give you both credit @rgardner@Kbird1. I thought I had clicked on Ryan's response and then wanted to see if I could click on the Mick's reply as well. Had no idea I clicked on my own. People are quick to hate these days, rather than give someone the benefit of the doubt. Regardless, note taken on the etiquette. Thanks again both of you! 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 11, 2023 Share Posted January 11, 2023 3 minutes ago, OldBarnDesign said: It was literally a mis-click. You both helped me solve the problem and I couldn't give you both credit @rgardner@Kbird1. I thought I had clicked on Mr. Gardner and then wanted to see if I could click on the other reply as well. Had no idea I clicked on my own. People are quick to hate these days, rather than give someone the benefit of the doubt. Regardless, note taken on the etiquette. Thanks again both of you! No harm done here Cody...... your are right about the Haters these days..... M. 2 Link to comment Share on other sites More sharing options...
