Problematic wall niche and more
marlem2000
Go to solution Solved by Kbird1,
1 hour ago, Kbird1 said:
this can be done by navigating to 3D> Lighting> Add Lights addlights.png?1643818217     but since you can't see them in 3D cameras you can place them anywhere , more about it near the bottom here :
https://www.chiefarchitect.com/support/article/KB-00777/working-with-lighting.html
I have a bit of more light now. It's not enough yet but I think this option can help.:)
I can see in the pics above your computer has (2) Graphics cards , so you do need to check the Render Tab in Chief and make sure Chief is using the Nvidia Card. Show me your Render Tab pls.
I have configured Chief Architect for a high performance with my graphic card. Now it seems the soft is a bit faster. Anyway, I keep on getting problems with the dark screen in the night view. Probably there's something I'm missing or it's just a problem of my card.:unsure:
Trying installing the latest Nvidia Driver ( you have 512.15 ) suggested by Chief to use   Version 526.98  or  526.86 which I am using from November, it may or may not help with the black screen problem.  This is my Thread/posts to the best Nvidia Drivers in Chief.............
https://chieftalk.chiefarchitect.com/topic/16205-nvidia-drivers-updated/?do=findComment&comment=281778
Thanks, Mick! :)I've just installed the version 526.98 but, for the moment, there's any change at all. I'll restart my computer and see what happens.
One last question not related to this: Is there any way to make a doorway like the one in the picture below? I have tried all door tools and I can make the arch on top but not the sides.:unsure:
1 hour ago, DavidJames said:
I would probably create the opening via Polyline Solid:
Hi, David! Many thanks for stopping by.:) Any detail about how you made the hole with the polyline solid?
It is likely then that the 960 doesn't not 100% support the new 3D engine in X14 then, you could perhaps look for a new 3000 or 4000 series GPU or even a used GPU in the 2000 Series depending on your budget, if you are not considering a whole new computer of course.
I don't think it's a Hole , he has broken the bottom edge and just pulled it up............ you can do the same thing with a Wall in Elevation , however a Wall can't have the Radius curves..... hence why I think David used the 3D Solid , it also will not show the framing like a wall when "cut" which needs to be patched.
image.thumb.png.d281e242689d7edf736068c6a018f8ca.png  image.thumb.png.33c8781d542efc028e0823fc3422a14c.png  image.thumb.png.b611168a5bb421d94f428e03531132df.png
No problem at all :)
This particular design can be achieved by drawing the polyline solid in plan view, and then adjusting the extents in elevation view.
While still in elevation view, you can then select the bottom of the polyline solid and break it into segments (using the "break tool" or F3) which will allow you to create an opening and adjust its shape to whatever you prefer aesthetically.
I keep on getting problems with the black screen so I'll have to think about another graphic card or, maybe, a new computer (the one I have is old).:unsure:
I have walked my first step with the wall ellevation view. Many thanks for the help:)
That is my suggestion if affordable.......  but if you can get a 2nd hand (used) 2000 series like a 2070 Super , it mybe enough to last you a few years yet :)
If that is a Solid you can add an ARC ( curve ) by adding a small angled piece ( add a break) and then use the ARC Tool and then the Tangent Tool to smooth it out if needed.
image.thumb.png.c12d247bc12c34968695a3d27ef7f24d.png  image.png.35b21d6de113950e629a0977295ff8bf.png
I'm a bit stuck in all of this. The doorway doesn't look well cos it's made by hand (I don't have any kind of method to do it).:unsure: I just use a polyline to make like a "guide" over the wall. I don't know what I need the solid polyline for. I think I'm lost :(
Only if you need an ARC or curved section , if you break a Normal Wall it won't allow the use of the ARC Tool  ( unless that changed in X14 I didn't try it )
PS..... Chief LOVES to snap to CAD Lines , so you can use them and setup them with Dimensions and then "snap" the Wall/3D Solid Points to them.
12 hours ago, glennw said:
Or...if you really need it to be a wall, you can use the Inserts Into Wall option for a symbol.
This option then allows you to make any shaped wall opening that you want.
Where is the "Inserts Into Wall" option? It sounds interesting. Maybe I can try to build carefully my own shape with a polyline, convert it into a symbol and do the rest.:)
I know Chief loves to snap. In fact, sometimes I have some problems with that so I use the Ctrl key to avoid it.:D Anyway, I must confess the snap option has saved my live 95% of the times.:rolleyes:
For me it's difficult to create a balanced shape, specially with curves. I'm not too quick with the tools.:(
Oh yes the CTRL key is a must , as is zooming in ( mouse wheel needed 100% ) to be accurate
I was suggesting using a grid of CAD lines spaced with dimensions , so everything is balanced and 100% accurate.....
I'll leave Glenn to explain the "Inserts into Wall" it's not a Tool I use much.....       @glennw
    33278
    markstevens
    markstevens
  • Similar Content
    • By marlem2000
      Hi, everybody
      This question is not exactly related to technical issues about Chef Architect but I don’t know what to do. Let’s see… how can I explain this?
      I’m really bad designing my own furniture so I usually download stuff from pages like 3D Warehouse. I save everything in the User Catalog. I try to keep everything in order and in different folders but, as you can guess, working with so many things is a mess.
      I try to clean these folders regularly removing furniture I don’t use anymore but my hard disk is a disaster. I’ve been updating the software and now I don’t know where all the libraries are (including the stuff I downloaded). I’m scared of deleting the wrong "Chief Architect Premier X Data" folder.
      Then, another strange thing that happens while working with downloaded symbols is that, after adding them to my catalog, their textures are lost. Doesn’t Chief Architect keep them?
      I don’t know if I’m missing anything… How can I “clean” the software? Many thanks!
    • By Kbird1
      Tip Added here after being found buried in a post in the Q&A Section as I thought it would be useful for Others, Thx Chopsaw.
        *I have also added some PDFs and links for GIMP.
      Making SEAMLESS TEXTURES using Gimp.                    * this info is in the PDF below too
       It's an open source (free) photo editing software available at https://www.gimp.org
      Tutorials are here : https://www.gimp.org/tutorials/
      Direct link as of :
      Mar.13th 2023
      https://download.gimp.org/gimp/v2.10/windows/gimp-2.10.34-setup.exe
      1. Open the image file in Gimp.
      2. Edit > Copy, then Edit > Paste as new layer.             Paste it as a new layer three times so you have a total of four copies, each on their own layer.
      3. Image > Canvas Size. Exactly double the width and height of the image/canvas size.
      4. Use the alignment tool to align each layer in its own corner (so they are all visible, not overlapped).
      5. Use the "flip" tool to reverse/mirror three of the layers. Leave the top-left corner alone.
              Reverse the top-right corner horizontally.
              Reverse the lower-left corner vertically.
              Reverse the lower right corner horizontally and vertically.
      6. Export the new image. This will now be a seamless texture when tiled. Choose it as the texture file for your material.
      7. Adjust the scale of your new material since the size of the image is now larger.
      * the Info above is in the PDF below too
      SEAMLESS TEXTURES USING GIMP.pdf
      I also made a PDF of the Latest Release Notes
      GIMP 2.10.20 Release Notes.pdf
      Mick
    • By marlem2000
      Hello!
      I hope everybody is enjoying this year that’s ending.
      I’d like making a question before 2023 comes. Is there a way to make some kind of “up holes” in a wall in order to set some puck lights up too?
      First, I tried with a wall niche but it’s too thin. I don’t know if I’ll have to use a pony wall or other but I have never worked with them so I’m feeling a bit lost. Any idea?
      Many thanks and Happy New Year!
    • By MN_JohnH
      I can't figure out why my walls are not meeting the roof.
      I run into this a lot and usually finagle walls by puling on their handles etc but changing from gable wall to hip wall etc seems to make no difference in how the wall acts.
      I just want them to act like when I first drew them where they just automatically connect with the roof.
      plan.plan
    • By KimJansen
      Dear CHIEFERS, can someone please advise me on how to create new foundations that will then be the default foundations - as shown in attached image.
