One story ranch house with detached garage
SkullMesaRanch
Go to solution Solved by Chrisb222,
I haven't started my project but would like to know if I can have the house model and detached garage in the same project.  Is this the best way or should they be in separate projects and then combined in the condocs?    The house and detached garage have similar structure; same walls, roof type, height, foundation.
I can't seem to find an example on the site that gives this information.
You can do both.  Depending on the complexity and size of your main house sometimes it is better to do the detached garage in a separate plan file.  Another advantage of a separate plan files is if your floor heights and ceiling heights are different from your garage to your home and you want to use all of the automatic tools.  Personally I generally model them in separate plan files.
  • Solution
Since your walls, floor and ceiling heights are the same, I would model it all in one plan. One advantage is if you're doing a site plan, you can situate the two buildings as they will be built and keep your property line, site plan dimensions, setbacks, etc all organized and together.
  • SkullMesaRanch changed the title to One story ranch house with detached garage
