Adam_Gibson Posted March 15, 2014 Share Posted March 15, 2014 This isn't really a new topic, but what's the best way to create limestone or brick sills under doors? No problem with windows, since there's a Sill tab. I've created the profiles, but I see no place to apply them as we do for windows. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted March 16, 2014 Author Share Posted March 16, 2014 Aw, c'mon! Nobody does this? Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted March 16, 2014 Share Posted March 16, 2014 The way I do it is to use a p-solid, but you have to "fudge" the door height so the CA door sill doesn't show. For years many have been asking CA to have more control over both door and window sills. I've been asking since version 10 (2006), but I know it was being asked for before that.Whenever a new version comes out the first thing I look at is to see if or what improvements were made to doors and windows. Then I think---maybe next year. For now the best "I" can tell you is to make it look as good as you can in render/vector view and then adjust what you have too in a cad detail cross section if you need to really explain what you want. After that go to Suggestions and ask for more control with door and window sills. I've been told in round about way that CA the "squeaky wheel gets greased". SQUEAK, SQUEAK, SQUEAK! Link to comment Share on other sites More sharing options...
Adam_Gibson Posted March 16, 2014 Author Share Posted March 16, 2014 Thanks Larry. I do something similar but I guess I was hoping that things had been improved! Link to comment Share on other sites More sharing options...
Adam_Gibson Posted February 1, 2018 Author Share Posted February 1, 2018 Revisiting this almost 4 years later. Anyone have a faster method? I use the Sill option for windows all the time. Link to comment Share on other sites More sharing options...
justmejerry Posted February 2, 2018 Share Posted February 2, 2018 I use a moulding line for this. Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 3, 2018 Share Posted February 3, 2018 The whole exterior door frame and door sill has a few issues. I can never get the exterior door jams to look right, all kinds of z-fighting and color blending in from the interior. Door sill as you mention is a work around with p-solids. I really wish we could cut a cross section of an exterior door and then individually select the sill and shape it. 1 Link to comment Share on other sites More sharing options...
Smn842 Posted February 4, 2018 Share Posted February 4, 2018 Even as a hobby user I find the door frame and sill issues annoying. Also the lack of inset control which I didn't find an easy workaround for (makes modelling UK style construction very difficult). I did try playing around with using tiny sections of a different wall type but it got very messy to maintain especially with working around a visible wall cavity in some cases. Link to comment Share on other sites More sharing options...
