Ange822 Posted December 5, 2022 Share Posted December 5, 2022 Good afternoon, I am having issues with a fascia board missing. I have tried re drawing it, moving it up / down / side to side slightly and nothing seems to work. Not sure if this is an easy fix but I can easily draw a polyline! Thanks in advanced. Link to comment Share on other sites More sharing options...
robdyck Posted December 5, 2022 Share Posted December 5, 2022 Hi Angela, you'll probably need to post the plan for help with this issue. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2022 Share Posted December 5, 2022 Hard to tell from the pic , you haven't just assigned the wrong material to it have you ? ...looks like siding to me in pic... another thought - have you rebuilt the framing ? otherwise as Rob said you might need to post the plan. M. Link to comment Share on other sites More sharing options...
VHampton Posted December 6, 2022 Share Posted December 6, 2022 The fascia and roof edge(s) of gable end return and primary gable appear to be at the same elevation. The attached may or may not be the desired look, but it works. The primary roof can be "broken" along the rake boards so that a hip roof section can be created with the gable end return. Note: Per Rob and Mick, you should probably post the plan file. In X-14 what your plan file is showing has been a bit of an anomaly. The fascia on the gable end return should exist, even if it doesn't merge with the rakes on the main gable. Link to comment Share on other sites More sharing options...
