Line Weight Changes Not Showing Up in Elevation View
Renerabbitt
I haven't messed with my setting in a while so I may be missing something but none of the line-weight changes I am applying in a vector view elevation are showing up.
You can see when I select something that the line weights show up.
You can also see that I have line weights turned on
what am I missing?
I don't remember if it's always been this way, but it certainly has for some time. Line weight do not display correctly in the Vector View technique used for elevation / section views.
They display correctly in layout, but not in the native view. In the image below, I've shown 4 example with line weights turned on. I've added CAD lines in red that match the line weights for the material pattern, the Walls Normal layer, Walls Foundation layer and Terrain Perimeter layer.
The CAD lines display correctly, the model does not.
