Caddman Posted November 14, 2022 Share Posted November 14, 2022 Hello, I can't seem to find the fix for my issue, hopefully someone can help out! I have a plan I am working on that has a detached garage, but the issue is it keeps it at the same elevation as the main building. The property has a slope, and the garage will be lower that the main home. Since the main view from the home looks at this direction, it important in the design process to limit how much the garage structure interferes with the viewpoint, so adjusting the proper height is important. Thanks, in advanced!! Link to comment Share on other sites More sharing options...
Solution joey_martin Posted November 14, 2022 Solution Share Posted November 14, 2022 The garage is a "room", open the dbx for the room and use the structure tab to set all the heights relative to 0'-0", which is the sub-floor of the home. If the garage is 3' lower than the house, then you need to tell Chief that. 1 1 Link to comment Share on other sites More sharing options...
lbuttery Posted November 14, 2022 Share Posted November 14, 2022 many find it easier to create separate buildings in a separate plan then make a symbol of the building and place the symbol in the library then place the symbol(s) in the master plan much easier to control placement etc can it be done in one plan - yes, if one is very familiar with all the tools I prefer the simplicity of separate plans Lew 1 Link to comment Share on other sites More sharing options...
Caddman Posted November 14, 2022 Author Share Posted November 14, 2022 On 11/14/2022 at 11:11 AM, joey_martin said: The garage is a "room", open the dbx for the room and use the structure tab to set all the heights relative to 0'-0", which is the sub-floor of the home. If the garage is 3' lower than the house, then you need to tell Chief that. Expand Thanks I’ll give that a shot Tomorrow, I’m guessing that method I will have to refer to the garages in the main house as something else… Link to comment Share on other sites More sharing options...
Caddman Posted November 14, 2022 Author Share Posted November 14, 2022 On 11/14/2022 at 2:23 PM, lbuttery said: many find it easier to create separate buildings in a separate plan then make a symbol of the building and place the symbol in the library then place the symbol(s) in the master plan much easier to control placement etc can it be done in one plan - yes, if one is very familiar with all the tools I prefer the simplicity of separate plans Lew Expand I typically would do something like this however I need to show the client how the separate garage is viewed from the second/main floor of the home. Their concern it the roofline will block to much of the view … hence the need to put in same plan to illustrate how much view it takes up, and how the accuracy of the elevation plays into the view Link to comment Share on other sites More sharing options...
robdyck Posted November 14, 2022 Share Posted November 14, 2022 On 11/14/2022 at 3:11 PM, Caddman said: I’m guessing that method I will have to refer to the garages in the main house as something else Expand You wouldn't have to change the name, it has no structural effect.. But it might be a good idea to rename the detached garage to something like..."Detached Garage". Then when people are discussing your plans, everyone will be able to know what the other person is referring to...as long as you can find people who are clever enough to refer to a room by it's actual name. 1 Link to comment Share on other sites More sharing options...
lbuttery Posted November 14, 2022 Share Posted November 14, 2022 I need to show the client how the separate garage is viewed from the second/main floor of the home the garage symbol can be seen from the window - same as if it was in the same plan Lew 2 Link to comment Share on other sites More sharing options...
Caddman Posted November 15, 2022 Author Share Posted November 15, 2022 Thanks, that achieved what I was after, I had attempted that before, but my mistake was in not changing room label in the main home, so it messed those heights up. Link to comment Share on other sites More sharing options...
